They only go in one direction and they're in correctly.ummmm they are not in backwards are they?Are they 1 piece or 2 piece and the `washer`part is on back to front?
They only go in one direction and they're in correctly.![]()
Probably about 1mm or under 2mm certainly less than the unevenness of the wallSorry never used them myself
How proud are they?i.e. how many mm do they stick out from the board?
Aye its a mcalpine bath waste so fairly good one. I emptied a full bath and was leak free so just the overflow element seemed to come back "up" through the waste trap when it was all completely full.Is that a new fitting? Trust me applying a sealant to stop a leak is a bodge that will fail with time.
Battens definitely!Any thoughts on fitting battens? Necessary? I'd rather not have to remove it all...![]()
Battens definitely!
While i was not a plumber before i retired i ALWAYS ended up cutting 4x1 or similar for the plumber to put under the legs.ALL of them inc the middle one
i.e. a length of timber about the width of the bath,from wall to just beyond the outer leg.Spreads the weight and makes sure in the future a leg wont go through the floor with a fatty plus water
And if you end up refitting i recommend putting a batten under the bath rim to the wall,both long and short sides if possible
another edit
looks like you can wind up the feet/legs and slip a batten/timber under if you really do not want to take out bath
I'll just drill them right through and get some plugs into the substrate? Should be OK I think.Not sure how useful battens are going to be on Marmox. Unless you put in vertical supports too ?
It's probably too late now, but you're actually supposed to stick the spankers inbteween two panels, so one spanker essentially 'joins' them together. You then use a board fixing silicone type material to seal them all in and splurge between any gaps. Your version will probably work fine though!
Oh I see! Think I was thinking of the tile board wide washers and screws, look really similar from photos, but different behind the wall.No. Spankers are designed 5 per board smack in the middle of a dab.
