For the price of a tanking kit.....just tank it.
He is, and he is using better products than your old style 'tanking kit'.. New and better ways of doing things are out there now.
pretty expensive to tile it all at 2.7k
Cool. I laid mine straight onto the floor boards first time, and it ended up cracking.
I didn't factor in that the underside of the tray wasn't flush to the ground, and one half of the tray was incredibly thin (about 3mm!). I've replaced it now and added various sized blobs (according to the depth) so the underside of the tray is supported consistently.
I used a mix of ready mix cement + extra sand + PVA. Looked very similar colour to yours.
Nope!Are you tiling under the bath
If it’s 15mm I found ones that are 10mm bore, should be okay. To be honest will be very very irregular use until/unless I have kids.Prob crap flexi with a tiny bore anyway so might end up replacing them ? I used solid tails on mine
