Permabanned
- 28 Sep 2018
I know this batted around a lot so I figured I'd share my findings. The results are below and everything is exactly the same in bios. The air cooler was cleaned. All fans are 100% I use realbench not because of some magic reason. Only because I knew I could run it just shy of throttling the CPU on air.
Settings:
9900k
HT OFF
5.2ghz
1.305v in bios
z390 aorus pro
Turbo LLC
46x core
Case = haf x with side panel off
Dark Rock 4 results:
Alphacool 360LT results:
Settings:
9900k
HT OFF
5.2ghz
1.305v in bios
z390 aorus pro
Turbo LLC
46x core
