AMD - How to Change The Power Control/Limit from +20% to +50%
Probably matt, at the price they have been going at, there must be plenty more getting setup now.
Op updated btw-don't copy my data tables as both gpus in those tables are low Asic gpus(yes I left a hint there for the crazy folks with selective reading:p), modify your own.
Too double check, I have been having low GPU usage lately on both cards but mainly the Ice-Q Boost in Crossfire whilst running 1175/1250 @ 1.250v, 35% Power Limit.
Only just had a go at increasing the Power Limit to 45% and the GPU usage go up and stays pretty high. Would it be safe to use 45-50% with these clocks?
Tom
Try swapping the cards round to confirm it's the boost at fault.
Test the normal limit (+20%)temps on a loop of Heaven BM, take a note, then try out the +45% temps on the same loop of Heaven BM and compare, if the temps are similar, then it should be good to go as the Limit hack afaik can't push the TDP value further than what is set in the bios.
Just tried this with my HIS 7950 Ice-Q, set at 1100, 1500 and 35% over. I'm now getting around 910 on the Heaven benchmark. Noticed my temperature is around 82 degrees, using stock cooler. What's a reasonable temperature?
Default fan profile is slack. At those clocks 1100/1550+ id be looking to keep temps below 80c or lower where possible.
It's currently on auto. Should I set it at something specific? What would you recommend?
I'd recommend flashing the 0.950mv bios from the OP. Then setup a custom fan profile using msi afterburner. Set it at 40c =30%, then 60c=60% and 90c=100%.
Cool, I'll give it a go when i get chance.
EDIT: just set up the fan profile and it finished the Heaven benchmark at 76 degrees this time. The fans bloody loud though :/
Using what voltage? If its 1.25v that's hardly surprising. 1.175v -1.2v should be enough for 1100/1500.
Thanks very much for this guide.
Noticed that even with the BIOS on my ICE-Q 7950s flashed the power limit was being locked down to 20% when using Windows 8 secure boot. Now unlocked again with this bit of registry fiddling. :)
Big update to the OP, added a Bios Mod guide using VBE7 for a more permanent Power Control/Limit Fix.
Matt, hope you don't mind I used(and changed for this thread) your bios flashing guide.;)
Why do you say don't jump to +50% power limit in the guide? There should be no risk to doing so, all you are doing, just like with CPU overclocking, is changing the limit on how much power the chip draws.
Nothing wrong with that, if chip wants more power, give it more power. It's not going to magically use 10000w and blow up, it'll only use ~350w as it desires. The problem is AMD put in this stupid stock power limit because they wanted to say 'See our card super efficient only 250w!, way better than nvidia!' when in reality it's more like a 350w card (and uses way more power than nvidia too for same power).
I mean obviously it'll run hotter, but even running 800mhz 100% of the time is way better than 1100mhz overclock that throttles so it's averaging 600mhz and has choppy performance, but it's not clear you are saying that...
Twofold:
I'm not an Amd engineer and don't know for sure there would be any long term damage (if any) running at +50% and don't want any grief for anything that goes wrong by doing so.
A much higher chance of introducing coil whine kicking in too running at 50%.
The main aim of the thread was to negate boost spiking, higher oc's was just a bonus tbh.
is there seriously no way to PM someone on this forum? Tommybhoy, answer me goddamnit.
I wrote a guide with your info in it too:
http://www.overclock.net/t/1394623/belials-comprehensive-guide-to-7950s/0_100
If you read the FAQ, it would tell you to use the trust function to send pm's.;)
Nice guide btw.
Twofold:
well... you could literally say that about anything... Don't overclock your card, you don't know for sure if any long term damage running at 1000mhz, dont underclock your card you dont know for sure if any long term damage running at 800mhz, don't use your card, you dont knowf or sure if any long term damage if you use it!
Using a card will always 'damage' it, but it'll still live a good 10-20+ years. Obviously, using +50% power throttle will cut the lifespan, but in the same way that running your card at all will degrade it more than never using it. Using something takes a toll on the engine, but using +50% power limit isn't going to do that.
Like running 800mhz@+50 power limit is better than running 1200mhz with 0 power limit due to smooth performance vs massive throttling, and it'll also probably live longer as well (ie higher 'speeds', voltages, logics, etc, always more harmful than lower).
wut? This sounds completely made up. If you mean by there's a higher chance of introducing coil whine, or you really mean VRM overheating, not coil whine, coil whine is a byproduct of overheating VRM (though can happen in odd other instances like menu in BF4, when you hit 200+ fps, etc), because you are actually utilizing your card, sure, but saying that +50% power limit inherently has a higher risk of coil whine (dont you mean VRM overheating...?), no, that it simply untrue and unfounded and complete conjecture. Again, 800mhz/1.1v/+50 will not have any more VRM overheating than a 1200mhz/1.25v/+0.
Well raising your power limit will 'lower' your overclock, but really it shouldn't affect your overclock at all, just in practice it does because people don't know what they are doing. If your card throttles heavily, it's going to pass stress testing much easier because running at 1200mhz+0 will run an average of ~800mhz, much easier to do than running 1100mhz 100% of the time and not throttling.
I understand that if you raise your power limit, you no longer have throttling on your card and thus your card, operating at it's full potential, will run hotter, a hotter VRM, but the +50 power limit inherently does not cause higher VRM temps or cause degradation. The same things as always cause degradation - high voltage, high temps, and the same things as always cause higher VRM temps - more power being consumed by the GPU.
I was just quite confused and it was a little misleading to say things like "dont jump to +50 right away", etc, in the guide, with no clarification on why. I thought there was actually a legit reason that I was missing out on.
Of course, overclocking, not overclocking, power limits or not, make sure your card's temps stay reasonable. Just because you dont mess with the power limit, doesn't mean these factors aren't important.
Thanks for the compliment, your guide is great as well. I have it posted over at Anandtech and there's literally a bunch of people in there saying their cards don't throttle with +20 "because it runs good in bf3". It's amazing how stupid some people are.
Not made up at all, first hand experience of applying 40-50% introduced coil whine when there was never any instance at all.
if I thought it was anything to do with vrm temps I would have laid mention to them as a possible cause, at a guess the higher limit was putting more stress on the psu rails causing the whine.
Again my aim in the thread was to negate spiking, not to introduce any other problems.
Well coil whine occuring on 40-50 power limit simply means the card is running hotter because it's not throttling. Of course coil whine will happen when the card runs hotter, of course the card will run hotter if its not throttling and is actually being used. A chip will run hotter at 100% utilization than 90%.
It has nothing to do with the power limit, the card would have coil whine on increased voltage or higher ambient temps all the same. Coil whine is a byproduct of hot inductors.
Well it's really misleading, I read it as +40-50 power limit is inherently dangerous, when it's not.
A better way to put it is 'Be aware raising your power limit will increase temps'.
I mean there's not a significant difference between +20 and +30 (though some, as we see), so if you can do +20, you should be able to do +30 just fine.
And as he states in the OP himself, there's basically no difference between +30 to +50.
So why does he state +50 as dangerous?
I mean it discourages people from doing his fix at all. I've heard multiple people quote that as a reason not to do this, but fact of the matter is you are just removing the governor, you are removing the power limits just like people do for the CPU and RAM. There's a difference from telling people to be careful of something, or educating people that raising the power limit will increase temps as your chip is used more (just like more cores, HT, and higher frequencies raise temps on their own, with same voltage).
I mean it'd be like writing a guide to crossing the street, and then saying DO NOT RUN ACROSS THE STREET ITS DANGEROUS. Well is running across streets dangerous, or just not paying attention dangerous in which case it'd hold true even if you walk. The OP makes it seem like the power limit fix is dangerous, when it's really just high temps are dangerous and raising the power limt, like many other things, can raise temps.
