Ok, first issue.
1110/1200 was fine.
Stepped up to 1135/1200 - BSOD as soon as I entered into Unigine. So now I need to step voltage up by 7 digits.![]()
Whack it up two notches seeing as it gave you a BSOD. That's pretty extreme, typically you'd just get a driver reset, black screen or such.
So 2 notches would be 14 digits? Just a bit confused. If it's 1140 at stock it needs to be 1154?
Also, should I be worried about that BSOD?
Can anyone else advise please? Desperate to start going again.![]()
Thanks, it ran through fine that time with 1135/1200.
I know you stated in your other reply to keep upping the coreclock speed to a limit I'm happy with but as I'm a total newb, I'm really not sure what sort of number I should be aiming for?
Your help is greatly appreciated btw, many thanks.
Cheers
Cheers mate - I ninja edited, don't think you saw it in time.
1160/1200. 1155mV. BSOD as soon as Unigine was loaded. What should I do now?
Thanks.
Sorry to keep asking - I upped voltage to 1165 and got another bsod. Will it be safe to notch it up again to 1172? Not really sure how far it's safe to push voltage...
Thanks.
What's your stock voltage?
Btw you do have the power meter at +20% in afterburner right?
Hey matt how do i stop afterburner applying clocks but not voltage at boot
Voltage is safe all the way upto 1.25v for 24/7 usage, i wouldn't go over that for 24/7 some people may suggest higher but thats up to you.
Stock voltage appears to be 1138 and I'm damn sure I set the power meter to 20% but It obviously didn't save. Agh. I'm such an idiot. With not having that at 20%, is it likely I've damaged the card or anything?
Haha, I've made a right hash of this so far! To be fair though I've never done anything like this before but it certainly goes to show that you need to make sure you read everything properly and take your time.
So, I reset the voltage back to stock and now Power Limit % is saved at 20%.
The last stable clock was 1085/1200 with stock voltage. Should I just start from there again and work my way up as usual?
Many thanks
yes mate
