Thanks Matt. Ive just turned crossfire off and my frames have easily doubled! Silky smooth,.
Arma 2 OA running 35fps with xfire enabled 60-120fps disabled?! WTF?
Cheers for the reply Matt
Afterburners up to date I think - v3.0.0 beta 10, CCC 13.6 (with driver version 9.14.10.0972).
Didn't realise the patch wasn't necessary anymore - might just do a clean reinstall of CCC and Afterburner then. Been tinkering with the memory as well, seems that on stock v it'll do around the 1375 mark.
So the spiking on the VDDC ampage is ok then, or is it just GPU-Z glitching? Reason I ask is I had conflicts with GPU-Z monitoring a couple of days ago with some of the readings being at zero. Also had the clock problem with the GPU not downclocking when idle.
Ta again fella, and as you're from Norwich, a big AH-HA (bet you can't wait for Alpha Papa)![]()
Thanks for that I tried your method and didn't get very far I'm afraid. Standard clocks are 1000/1375 and I can get 1135/1490 completely stable all games etc through CCC.
In order to improve this for the upcoming BF4 I gave this method a go, and whilst Valley didn't crash, I got small black box artifacts appearing almost immediately. I tried upping the voltage, but still artifacts even at 1150/1500. At no pint did Valley or the PC crash and temps are fine.
What am I doing wrong ?
Not sure about the spiking, id image its nothing to worry about. If you use Driver Fusion in the OP it should remove the traces of that old patch file. Make sure you uninstall afterburner and don't keep users settings. Make sure to delete the program folder as well, just in case you installed the old patch files in there.
Gotta love Alan Partridge. I'm not actually from Norwich though (thank god) just living here.
Well, tried out 3.0v @ 1202mhz CC - stable in 3dMark11 and Valley/Heaven. V-droop sinks it to around 1.26v.
Sadly though, been using MWO beta to test it out and around 50% of games results in a crash (black screen, audio still present). Maybe it's the bad coding of MWO so might be worthwhile trying out in other games?
*cough* meant to type 1.3v![]()
I got this spiking when i upgraded to 13.6, theyre not a glitch in GPUz as it shows it in all monitoring progs, im thinking theyre not working well with sum bioses, i just ran driver fusion again and went back to 13.4, it sorted it. Ill wait for hte next beta i think.
Sound advice, these dual bioses are a godsend, i remember having a Epox 8rda Mobo where i had to keep 2 spare bioses cause it used to corrupt them so often.
Cheers Matt- you read my mind on that one as bios flashing was me next q.
Done a fair old amount of flashing back in my modding days - not on GPU's though. 'Scuse the ignorance, but flashing the HIS bios (onto bios block 1) will give me a bit more bang for the buck on mhz/v levels and reduce heat? I'm guessing though that if my card can't do 1202mhz on 1.30v flashing this bios won't give me more headroom to make 1202mhz stable as it'll be my chip?
And a final q (promise) - is it worth flashing a 7970 bios to my 7950 as my pcb's a 7970?
Ta again![]()
