- 22 Jul 2012
- London
I don't know how you guys have let the 'Chop so easily draw you into this.
GTX 580 was first with 3GB and then AMD followed that with the 7970![]()
Pfft.
AMD running 3/4Gb stock over a year on the 79/290 series, bwaa bwaa Nvidia copied AMD, AMD was out first....![]()
Maybe Kaap and not something I know too much about. The fact remains that both have it and both seem to work well in games. It is all good for us consumers and I imagine some of my old favourites like FSX would look very good on either DSR/VSR. The only real difference at the mo is the amount of scaling (that I can tell) and the amount of cards supported.
The AMD variant is very stuttery to me.
Some serious tearing going on in that on VSR. That would be unplayable to me.
As for Tommybhoy, you can argue those semantics all day but nVidia were first to release a 3GB card and a 4GB card, so throw that up as much as you like, you are clearly barking up the wrong tree![]()
I am assuming on the amd side they are using a 285 which probably explains the stutter or sluggish frames. My reasoning they use 4k. As for the tearing I noticed it a few times but it was far from happening a lot. I never checked out the Nv side and assume they probably used a more powerful card.
Maybe the fact they've been working on it longer is the reason it seems to be better so far in the few games tested.
This is also about dsr v vsr and what the effect does not who's game is running better. Performance has nothing to do with it.
You reckon you could go for a few posts without saying fanboys? Considering your obvious leanings, it's beyond ironic.
Seriously, do a search for "mmj_uk AMD fanboys"![]()
No, I have pretty good eyesight and worth seeing what others think.
I think you must have some Placebo seeing what you want to see going there Greg.
@ Tommybhoy
Getting a little desperate now Son and changed it from 3GB and 4GB to 8GB.... Nice one bwahhhh hahahahaha![]()
6Gb/8Gb by your logic then, who was first..............
Oh wait a minute better not count the 8Gb undisputed 4K champ.......![]()
Ahhh if you think the one on the left is smooth then maybe that explains why you dont see the stutter in your videos?
