Derek acorah just whispered in my ear,says sam said they will be out in a week or two
So I'm guessing that the new 4k series will have a 7nm IO die instead now? If so, whats the chances of being able to run memory faster, or will it make no difference?
It will be really revealing to see when the IO die moves to 7nm/5nm. At the moment GloFo 12Nm has fantastic IO libraries that outperform TSMC and Intel, and obviously something that is critical for an IO die. Worth noting that the 12Nm bigger node and substrate is inherently better for lower power and heavy IO work, especially for really high frequency stuff like DDR5 and PCIe4.0.
It's not just the desktop parts though, it is the new laptop U series parts that are all 7nm monolithic dies, and as they ramp up there will be less 7nm capacity left for alternate parts. However as the likes of Apple etc.move to 5nm this year 7nm capacity will be less crowded from the big players.
Good thing Zen 3 is moving to 7nm EUV then. Just at the right time tooit is the new laptop U series parts that are all 7nm monolithic dies, and as they ramp up there will be less 7nm capacity left for alternate parts.
Pretty ambiguous. But packaging changes to Zen 3 mentioned by TSMC & AMD at a joint event.
Perhaps I'm wrong about it sticking with the GloFo I/O die. Maybe it'll all be on 7nm+
If so, that likely means AMD are confident about wafer supply at 7nm+.
https://www.pcgamesn.com/amd/zen-3-tsmc-chiplet-packaging
That's exactly what we have right now.It would be good if AMD made two different designs, one for desktop(8 core I/O included) and one for everything else(8 core no I/O) and have the 14nm I/O chiplet from GF.
I meant desktop CPU's without the need for the IO die. Yes we have 2xxx and 1xxx CPU's but 3xxx split it into IO and compute chiplets. The only reason to do this I think, or main one, is the GF WSA, now that GF isn't even trying to compete they should let AMD use the best fab for the job - that being TSMC at the moment.That's exactly what we have right now.
Matisse is monolithic.
Matisse is monolithic. Would be interesting to see Zen 3 move to a 12nm IO die.
The IO chiplet is a very cool idea, and still is needed for the larger, Threadripper & Epyc, and the top of the line 12/16core CPU's processors. But for everything else 8core CPU's is a large enough market on their own to warrent it's own design - with IO incuded on the same die. As I said, I don't think it'll happen for Ryzen 4xxx CPU's, but in the future, with more market share, the IO die is a lot of silicon, not to say anything about the extra expense with chiplets/packaging, going to waste.
