** AN INCREDIBLE SSD DEAL: 128GB SUB £40 !! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
If you have thought about trying out an SSD, here is now a great offer:
SanDisk X110 128GB SATA 6GB/s 2.5" Solid State Drive (SD6SB1M-128G-1022i) @ £38.99 inc VAT
Features:
- SATA revision 3.1 6 Gb/s compliant backwards compliant to SATA revision 2.0 3 Gb/s & SATA revision 1.0 1.5 Gb/s
- ATA command set ACS-2
- NCQ support up to queue depth = 32
- Support for TRIM
- S.M.A.R.T. feature supported
- Advanced Flash Management
- nCache™ – Non-volatile write cache
- Dynamic and static wear-leveling
- Bad block management
- Background garbage collection
- Tiered caching – volatile and nonvolatile cache
- Supports multi stream
- Minimal write amplification
- Support for thermal throttling
- Windows® 8 WHCK Certified
SanDisk® X110 SSDs, based on 19nm MLC NAND flash, bring all the benefits and speed of high performance SSDs to ultrabooks, notebooks and desktops at a competitive price.
The storage device can be used as either a standalone or as a caching solution in a dual drive configuration. In both situations, X110 SSDs provide superior performance over the standalone hard disk drive, meeting Intel Ultrabook® performance requirements. The SanDisk X110 SSD is offered in a 2.5” and customized form factors, taking full advantage of the SATA 6 Gb/s high performance interface.
Was [£49.99] Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
This is very limited stock as OcUK is clearing them out! :)
This is nice - what's the best value 512mb/1gb SSD? Doesn't have to be amazingly fast, it's just going to be used to hold music samples/possibly images or video. Anything faster than HDD would be a bonus, tbh.
And probably going to have to connect it via lightning or usb3 anyway.
