Android Kit Kat...
Whilst we wait for our Nexus/Developer builds to get KitKat (I know it won't happen for at least a couple of weeks)... I started having a debate here with a couple of mates on what the 'Next' version (possibly Android 5) will be called!!...
I suggested 'Lollipop', one of my mates said 'Liver' (he's a iClone user!) and another said 'Latte' but I told him it won't be Java based!! :D
What do you guys think???
I hope the update comes out soon, ever since 4.3 my Nexus 10 doesn't seem to feel as smooth when switching between apps... lets hope the lowered requirements speeds things up a bit.
I'm hoping 3rd party launchers will take advantage of the transparent nav bar, so far needing to root for it is a bit annoying.
Lemon Sherbert!
Lollipop or Lamington?
Then perhaps Meringue, Marble Cake, Madeira or Muffin? :p
Does anyone know how to be able to scroll through the home screens on 4.4 like you could on previous versions, and by that I mean so when you reach your last home screen, if you continue scrolling you would go back to your first home screen?
How can you set a certain home screen as the "main" one which is the go to one when you hit the button instead of it going to #1?
Alarm clock widget seems missing from Widgets by default - just me or anyone else?
Never been able to do that on stock!, it's always needed a 3rd party launcher like Apex or Nova! :)
It's possible that's been included as the Google Launcher is pretty much built into the search app now, so it could be pushed to everything in time.
