Android Kit Kat...
Think I am the only person that thinks it is a lot better than Keylime Pie.
It think it's great. Certainly a lot more memorable that KLP. Also, when you think about it, as advertising is Google's business, it makes perfect sense. I will definitely be buying some kit kats even though they will taste exactly the same. Pure novelty :D
Does anybody know if Android just named it KitKat and KitKat jumped on the bandwagon or did KitKat go to Android?
Google went to KitKat. That's what KitKat are saying.
Since it's a trademark, google would have to have done that.
Apparently the Android guys at Google chomp a lot of KitKats so they went to nestle and asked if they could use the name.
Considering the amount Google have removed from the OS and turned in to apps you would've thought they could do the same with the navigation bar. Would certainly help with themes and customisability.
Really liking the potential cosmetic changes that we're going to get with 4.4-especially the transparent nav bars.
Its probably one of the only things that I like about Sony's current UI, transparent Navigation and Notification bars and core apps all colour theme based.
Maybe Google could handpick best features from all OEMs UI's and make a unified version for 4.4 :D
