Ok, lots of head scratching going on here.
To recap - Issue is that main pc has starting having odd issues when copying between nvme drives, and also it seems to be having issues in games too. In all cases, screen goes black, GPU fans go full whack and I need to reboot the pc. Seems to be running in background as I can still hear audio and able to triger a gracefull shutdown using power button. On reload windows has the GFX card down as disabled in device manager. No number of reboots or power offs sort it - I need to re-enable in device manager and reboot to get things back. Using windows 11. Also get it running various graphic stress tests in 3dMark as well, sometimes as soon as it tries to start, other times after a few cycles of the demo.
- Tried various versions of the drivers, used AMD clean utility etc numerous times, still the same.
- Tried resetting bios to defaults, disabled SmartAccess Memory - still the same. There was a slightly later bios which I also installed, but still the same.
- Ran Memtest86 for full scan and no issues found.
- Tried setting PCIE speeds to 3 for GFX slots as well as chipset interconnect - issue persisted.
- Tried my old Radeon VII card instead and everything fine then - played games (frost punk) for hours, stress tests ok etc. Put doubts on a general hardware issue?
- Tried the 7900XTX in another pc - older spec (Intel 4690k, windows 10, Corsair HX750W psu, PCIE3 slots) - played games (i.e Frost Punk) for a good while no issues. 3dmark stress tests also worked fine with a complete test of the DirectX 12 ultimate test etc - GPU was at 100% usage, temps looked fine in HWInfo.
- Tried moving the OS disk from the old PC to Main PC just to check if it was a Windows 11 thing - nope, does it on main pc with Windows 10, and does the same thing in device manager etc. Not seen that before, would think a reboot/power cycle would reset everything.
- Pc has been fine for general usage - web browsing, video watching etc.
So unless there is a weird driver thing going on here when in an AMD system, it's looking like something not right with board or cpu in my main rig. I'm using a 1000W Seasonic Platinum PSU, could try the 750W in main pc. It coped ok with the 7900XTX in the old pc, but then the AMD 5950x is a somewhat more power hungry cpu.
I used to have a 3700x in it originally but that went onto a B450 board for somebody else and I don't have access to it now - would have been useful to part swap. All I can think of now is to try a different board or cpu to try and rule out either, although have been using this setup for a good few months and only recently has it become this unstable.
Sorry for the rambling, been trying a lot of things and seeing if I can figure out things logically and wanted to get thoughts down while I remembered what I had done.
