Zip said:Can you add more ants to it?
Norbert666 said:There are about 30 ants in there. Most of them are all huddled up together on a piece of paper they came in. I need to try and get them off (without them all escaping this time).
You can't add more ants, as they'll just has all out war and kill each other.
Mind you, that could be interesting...
benneh said:I don't get why you dont just pick the paper up (or envelopey thing?, what exactly do they come in?), turn it upside down and flick it untill they all drop off?.
Norbert666 said:BUT HE MIGHT GO TELL HIS MATES THAT HE'S FOUND A WICKED HOLE...
Zip said:Will they breed and have babys then
Ant Porn
William said:Hmmm I am ordering one of them...
Edit: I was thinking:
You could make a slice of perspex to go straight down the middle of the tank and seal it with bluetack. Then you get the mail-order ants in one half, and garden ants in the other. When their bases are well established, raise the bit of perspex then watch the insectoid viet-cong warfare unfold.
William said:You could make a slice of perspex to go straight down the middle of the tank and seal it with bluetack. Then you get the mail-order ants in one half, and garden ants in the other. When their bases are well established, raise the bit of perspex then watch the insectoid viet-cong warfare unfold.
Read the paperwork. They can't reproduce.Norbert666 said:They all cling to the paper in groups and won't let go. they're protecting the eggs.
Feek said:Read the paperwork. They can't reproduce.
K.
Feek said:I refer the right honorable gentleman to the answer I gave some moments ago.
K.
penski said:Where does one aquire said ants and blue stuff?
penski said:When they 'fight', how vicious is it?
penski said:What are the possibilities of raising two sets, one wild then locking them up together?
