Grass is very hardy. I queried the interwebs and was told that pool and spa levels of chlorine won't hurt the grass, and sure enough the grass is fine.
I'm very tempted to do this when I empty mine next.
No, it is bad practice to use an extension cord and I certainly wouldn't be putting it anyway near the hot tub (water and electric and all that). I would have the socket moved asap and not use the hot tub until it has been done. Just because it has been working fine (so far) doesn't mean it is going to keep on working fine, you could end up with either an overheated and melted plug or a burnt and melted extension cord.Guys, I am running a Lazy Spa St Lucia, it is perfect for just me and the GF, and heats up fairly quickly, quicker than I expected but we have it in a good spot which gets sun most the day and it is also somewhat sheltered from wind etc.
Question...
My outdoor socket is IP44 rated, the tub wiring does not reach the hot tub so I have used an IP56 cased (55?) 13amp extension cord which is handling the load just fine and has been for a few weeks, is anyone else doing similar? I should really have the outdoor socket moved but this is working fine, I have ordered a 'dri box' to double up on the weatherproofing also.
Am I ok to continue?
Does your extension lead tell you the ratings of coiled vs uncoiled on it?Thank you however 13amp extension is sufficient it's the lower rated ones that have melted plugs and the extension is no where near the tub.
What do you mean by " the lower rated ones" ? All British extension leads are rated at 13 amp. It isn't the way that I would be doing it.Thank you however 13amp extension is sufficient it's the lower rated ones that have melted plugs and the extension is no where near the tub.
This, if you are going to use it uncoil it all just to be on the safe side I will state again and say you shouldn't be using an extension cord to power a hot tub.Does your extension lead tell you the ratings of coiled vs uncoiled on it?
I'll get some costs to move the socket.. in the mean time perhaps the better option is to run the cable through the window and plug inside directly instead of the outside socket
As the hot tub is switched off at night and only used on weekends this shouldn't cause any security issues..
Would that be acceptable?
Serious question why would the extension suddenly melt in this scenario?No, it is bad practice to use an extension cord and I certainly wouldn't be putting it anyway near the hot tub (water and electric and all that). I would have the socket moved asap and not use the hot tub until it has been done. Just because it has been working fine (so far) doesn't mean it is going to keep on working fine, you could end up with either an overheated and melted plug or a burnt and melted extension cord.
Also many hot tubs will have a slow flow pump to keep the water circulating 24/7.
Because we don't know what the extension lead is rated at or the specification of the hot tub, Even if I made a suitable 13 amp extension lead with a single socket outlet I still wouldn't use it. It needs a suitable IP rated socket hardwired to the consumer unit on its own dedicated circuit.Serious question why would the extension suddenly melt in this scenario?
Exactly, too many variables, now we are getting into cable distances and the cable size. That none of us know about. It's better to just say don't use it, and get an electrician in to install a new suitable outside socket if you're not competent in doing it yourself.Quite a lot are only rated at 10amps, and that rating falls if they are used coiled up.
The key thing is the cross sectional area of the cable used. This should be marked on the actual cable. For 13amps 1.25mm is the minimum, however 1.5 is better. If you're running over a long distance you may need to use a larger cable size which brings its own problems (mainly that 13amp plugs aren't designed for bigger cable).
If you're making up your own extension H07RF is the best grade of cable. It's the standard for the outdoor events industry and actually rated for about 600 volts due to its thicker insulation.
Make sure the supply to the hot tub is RCD protected, it should be if the outdoor socket has been installed correctly.
So no real reason then!Because we don't know what the extension lead is rated at or the specification of the hot tub, Even if I made a suitable 13 amp extension lead with a single socket outlet I still wouldn't use it. It needs a suitable IP rated socket hardwired to the consumer unit on its own dedicated circuit.
