You wouldn't use your car without an MOT, like you shouldn't use an extension lead that may not be up to the job and thus overload and burnout. An extension lead is the wrong item to use.So no real reason then!
Surely if its rated to 13a it shouldn't matter?You wouldn't use your car without an MOT, like you shouldn't use an extension lead that may not be up to the job and thus overload and burnout. An extension lead is the wrong item to use.
I would use a brand new car that suited my requirements without an mot same as I’d use an extension lead that was fit for purpose it’s not rocket science if the hot tub is safe plugged into a 13amp socket it is just as safe plugged into a 13 amp extension lead.You wouldn't use your car without an MOT, like you shouldn't use an extension lead that may not be up to the job and thus overload and burnout. An extension lead is the wrong item to use.
Hot tub ready to go in tonight.. 38c sat currently waiting for twilight. Bliss.
38c on a night like tonight will feel very warm. I usually go 37 when the evenings are warmer.
As it is your first service you will receive £50 off the standard price, making it £299.
We recommend a full service once a year to keep your spa in a healthy condition. This annual service provides peace of mind in the knowledge that your spa has been professionally cleaned and every working aspect inspected and function checked for performance.
- Remove and treat filters with filter cleaner. Recommend new filters where necessary
- Run chemical system flush (antibacterial and degreaser fluid used to clean internal pipework)
- Remove tub sides (where accessible) and inspect pipework for leaks and obvious faults
- Electrical check on control system
- Clean and protect hot tub lid with vinyl protectant
- Drain tub and clean tub shell with surface cleaner
- Vacuum out residual water in the tub
- Remove jets (where possible) clean and refit. Some jets may not be possible to remove without damaging them due to scale build up or other chemical damage. Customer will be advised if this is the case.
- Tighten all pump unions, inspect and replace any small seals if required
- Refill hot tub with fresh water, check operation of pumps, blower, lights and heater
- Rinse and refit filters
Thanks, that’s basically what I do anyway other than the 303.
Just watch your side panels when using 303, I did a little test on my composite sides and it had a strange reaction, 100% fine on the top cover though.
Thanks, I’ll keep it on the cover and maybe try a small bit on the sides first.
