When 1080p first hit the scene, the wise money kept away from it. If you look at the earlier 1080p monitors or TVs from the mid 2000s, you will know that they absolutely suck by today's standards and if you bought one back then, you will know how extortionately expensive they were compared with modern day high end panels. Same thing will apply to 4K without a shadow of a doubt.
i agree and all, but you forget, if it weren't for these "OCD types" that plow money into every new tech/venture, we wouldn't get every new tech/venture , as its that initial money that's been plowed into whatever new tech it may be, that funds the rest of its development , which makes it cheaper for the rest of us.
Uhh no, we are naught but market share, real profit comes from medium to low range, funnily enough.
Small yield, high priced items are simply PR.
What is it like as a 4K TV?
you picked up a budget 4k tv to play pc games no wonder you were left unimpressed. your ips monitor will be better for that. Try a 4k ips monitor
You're not unimpressed, you just made the mistake of not having a system to decently perform @ 4k and are misplacing your judgments on it.
Also, are you really running 1080p on a 4k monitor? I'm not familiar with any sort of scaling tech but won't that look extremely ugly compared to native?
So I've been thinking about this about recently. I have a 1440p screen as you can see in my sig. However when the other half is away I tend to play on my TV screen on the sofa (it's easier with the dog as she will happily sit beside but can't fit on the computer chair with me. She has tried!). I noticed I was getting a lot less problems largely because I was switching crossfire off so I got my old 1080p 120hz screen from upstairs and have set it up instead. Now it's only 60hz as I can't find my dvi cable but at the moment I might just stick with it and sell one of the gpus and the screen. The ease of everything more than makes up for any loss of picture quality (which I don't really notice so far, maybe witcher 3 a bit). There have been many nights where I've spent the evening getting a game to work only to then have no time to play it and get a whole new issue next time! This seems like the way to go. At least for me
I'm using the 40" Philips 4k monitor paired with x2 980ti in SLI & have to disagree.
Coming from 1080p the difference is immense, clearly it helps not having to turn down settings & a monitor is preferable to a TV usually.
ooh!
Heresy around here to go saying things like that. Naturally what you need is a GTX 980 ti configuration, running in Sli!
"That will be £1100 sir, thankyou very much have a nice day!"
"See you again next year for more of the same"
"thanks, bye!"
ooh!
"thanks, bye!"
