eXor said:![]()
Yes, no improvement over two cores in gaming.
Nice one braniac incase you didn't notice that is multi threaded for quad core. Unlike most other games out today which are not.
eXor said:![]()
That's just the point isn't it. For lots of people, most I'd say, two 4GHz cores is better than four 3.33GHz cores. Certainly is for me - I don't do that much stuff that would benefit and the stuff I do isn't time critical so I'm not bothered if something takes 10 minutes or 20 minutes to encode, certainly not bothered enough to spend money, have a hotter system and burn more electricity.Cob said:I'd rather have my four 3.33ghz cores than two 4ghz cores![]()
Teal said:If you don't have the apps and the usage pattern that need it then it is a waste to buy one.
If you do then nothing else will match it.
I'm sure there will be a good few people around who bought one because the price came down and not because they needed it.
MikeTimbers said:I've been considering a quad as an upgrade from an Athlon XP simply because they're perfect for Folding@Home. Serious crunchers.
robj20 said:If you are serious about Folding@home, then a PS3 is what you need that completes them in about 8 hours.
Vanilla said:The thing is i'm sure a Q6600 would destory a PS3 AND there is the fact that you don't generally leave a PS3 on all day and night like a PC (well, mine is on constantly!).
ergonomics said:you know EVERY game, whether multithreaded or not will see an improvement, as you can use the other cores to run every other background task
(may not be massive, but its true though)
Chris Beard said:Ah but there is an overhead to running more than one core!
