so it does NOT have a display port cable?
It does come with one
You might want to try a different DisplayPort cable. They can be incredibly finicky at higher resolutions and refresh rates. Out of the four I have, only one will reliably do 1440p above 60Hz.
i have a rectangle about 3"x 2" in the top left corner of mine where the screen is several shades lighter than everywhere else
i received the new display port cable & i now can seriously notice GHOSTING even when web browsing !!!!!!!!!!
Are you saying that the ghosting is different on different DP cables? Still 75hz? How about HDMI?
thank youYou accidentally turned on 'BrightFrame'. Disable it. Refer to my OSD video if you need to.
if this monitor can truly do 30-75 then its an even more crazy deal!
Hi
I just received my monitor. And when I run i-Menu it says that the monitor is a Q3279WG5B. On the panel it say Q3279VWF. Does everyone have the same information ?
I am also unable to update the driver (I am on Windows 10) it still says it is 1.0.0.0 25.06.2016 AOC Q3279WG5B
Does anyone have recommendations how to install the right driver (on the cd) ?
Thanks!
Some folk including myself have been extending the freesync range on this monitor, as it has been claimed to work at extended range 30-75.
I have tried this with the adrenaline drivers 17.12.1 but i experienced flickering and stuttering.
In the newly released 17.12.2 Drivers this issue may of been fixed according to an RTG Engineer on reddit.
https://goo.gl/FPzBBy
Its to do with LFC
Quote
"AMD_Aric RTG Engineer 1 point 59 minutes ago
There is a stutter/flashing fix for Freesync for the case where you are running in LFC. Looks like it didn't make it into the patch notes, but let me know if it helps!"
I will try again tonight to see if I can get a stable extended range
nice find, please try (also try 37hz if 30hz flicker).
anyone tried above 75hz? (display port only).
yes. but looking at the pixel size its probably impossible to get decent looking fonts that are small... what size of fonts is everyone using ? 200% ? 150% ? thanks
