- 13 Jun 2014
Hi
I just received my AOC U2868PQU from overclockers.co.uk and when I try to set my refresh rate to 60Hz I get very bad flickering and have to go back to 30hz.
The whole reason for buying this monitor is for the 60hz so the fact it doesn't work at all is most annoying!
I am using an R9 290 (also from overclockers) and the DP cable that came with it I am also using the latest AMD beta drivers on Win 8.1.
Does anybody know how to fix this as I may decide to simply return it and go back to 1080p as there is no point at all having 4k 30hz!
Thanks in advance.
Thanks in advance.
