hi i got my new pc a few days ago adn when playing battlefield 1 my gpu temps hit 84 degrees on stock fan settings, is this normal? as it seems to bee heating up my case as well, with my fans at 100% the temps go down to 66/67 degrees and cpu at under 40 degrees - im running bf1 at 4k, 120fps ultra, is there a better way to cool this down other than going 100% fans or are these normal temperatures?
only thing i can think of it taking the side panel off
CP-62F-IN Intel Core i7-7700K 4.2GHz (Kaby Lake) Socket LGA1151
Processor - Retail
HS-038-CS Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU
Cooler (CW-9060025-WW)
HD-36K-SE Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD -
OEM (ST2000DM006)
CD-003-OK OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
SW-172-MS Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
XX-003-OP Standard Build Systems - Dispatched within 7 working days
MB-54L-GI Gigabyte Aorus GA-Z270X-Gaming 7 Intel Z270 (Socket 1151)
DDR4 ATX Motherboard
MY-464-CS Corsair Vengeance LPX 64GB (4x16GB) DDR4 PC4-21300C16
2666MHz Dual/Quad Channel Kit - Black (CMK64GX
CA-021-KK Kolink Vault Midi Tower Gaming Case - Black/Green LED
HD-105-KS Kingston A400 120GB SATA 6Gbs 2.5" Solid State Hard Drive -
(SA400S37120G)
GX-001-AU Gigabyte Aorus GeForce GTX 1080Ti "Xtreme Edition" 11264MB
GDDR5X PCI-Express Graphics Card
CA-182-CS Corsair HX850i 850W '80 Plus Platinum Digital Modular Power
Supply (CP-9020073-UK)
NW-100-TP TP-Link Gigabit PCI Express Network Adapter (TG-3468)
Processor - Retail
OEM (ST2000DM006)
(SA400S37120G)
