Sorry I don't understand what that is? And how can I sort that? I'm new to pc gaming and tech forgive ne is it not good to get rid of warm air fast?well thats your problem. so obvious your AIO
Ok thanks, I think I'll have to increase the aio fan speed, what software do I need for this? As my gpu came with some so I can it's fans, I can't really do much about the cpu heat on the gpu can I?Aio = liquid cooler (your cpu cooler)
1) move your AIO to the top of your case (if possible)
OR
2) increase your AIO Fan speed
so if your CPU reaches 40C in game. @ 40C increase your aio fan curve by 25%
then the rear fan reduce it by 10% fan speed
this will give you more positive pressure and reduce temps.
you will still however be pushing hot CPU air onto a GPU.
you should be able to do it in the BIOS. 7Ok thanks, I think I'll have to increase the aio fan speed, what software do I need for this? As my gpu came with some so I can it's fans, I can't really do much about the cpu heat on the gpu can I?
the only fan i can seem to alter in bios is the cpu fan, i have a fan on my case for exhaust and the two for the aio cooler, i put my cpu at 40C - 60%, fan dont seem to spin any faster so is there some software that can do the same similar to MSI?you should be able to do it in the BIOS. 7
Ahhh now I see why your GPU was getting so hot lol
the rule I stick to is...cool air in the front..and hot air out the top and back![]()
..and as to fan speeds ...play around with the modes you can choose from..see what works best for you , even 70c is ok for that card
...my G1 gets to around 73c ...although my 1070 amp extreme would only get to about 48c lol
i can now relax with a super chilled pc and its cooling my room down to, just measured again with HWiNFO64 and under the full load the card only hits 55degrees and this in summer too - one question id assume you may know do i keep my cpu pump and fan at 2800 24/7 or turn it on when needed?
