System Panel Header on the Asrock Z68 Extreme 7.
I'm a bit confused with these plugs.
Starting with top row Left to right, what is the correct way?
And how do I know what way to turn the plug for + -
I connected the Power LED plug over near the clear CMOS switch, is this correct.
Thanks.
It doesn't matter which way round you connect the power and reset switches but the LED's need to be connected with the correct polarity.
The connectors will have a small triangle printed on for positive.
