- 2 Aug 2006
- Liverpool
thanks I think I'm going to leave the gpu on air and just wc the mb & cpu, next gpu I purchase will have a ekwb block available for it or will come with a water block preinstalled
would the two be compatible
thanks I'll shoot a message to them and ask
if it covers the power caps does that mean its compatible or not
ok I think I've decided on the final parts list,
here it is, how would I connect all the RGB so it all syncs up
Motherboard Block EK-FB GA Z270/Z370 GAMING RGB MONOBLOCKRadiator EK-COOLSTREAM XE 360
Pump EK-XRES 140 REVO D5 RGB PWM (INCL. PUMP)
Connectors EK-ACF FITTING 10/13MM - RED
Tubing EK-DURACLEAR TUBING 13/10 - CLEAR 3M
Fluid MAYHEMS AURORA 2 RED 1LTR
Fans Corsair ML120 Pro RGB 120mm Premium Fan with Lighting Node - Triple Fan Pack
Accessories XSPC PSU BRIDGING CONNECTOR
anyway to make it cheaper without affecting performance/cooling
My basket at Overclockers UK:
- 1 x Mayhems Pastel - Red Coolant 1L= £10.49
is that ok for regular use
