assistance required
yes to what question, rethinking fluid colour the case is the "Be Quiet Dark Base Pro 900 Orange/Black", should I go with clear fluid , orange or red
having a rethink, I'm just going to swap case for now and think if WC is really worth it or whether just stick to air,
You have a Dark Pro 900 ? Would just stick with that for air , easily handle Dark Rock 3 Pro and some serious air power with 3*140 at the front and 2*120 at the bottom then 3*120 at the top . So damn serious air power !
Though do fancy the smaller 700 case of theirs with vertical GPU mount and rgb
yes the 900 pro, ok can I ask for recommendations for the following
new rgb ram (low Profile) preferably an upgrade on my current ram (team dark pro 3000)
mb only has 5 fan headers
can only get 1 fan at bottom due to psu length
cpu cooler (preferable quiet but good cooling)
thanks
I recently had the Eisbaer 360mm, and it's a solid capable cooler, my biggest issue was that the tubing to the block from the radiator was too short if I had them coming from the right (CPU to the left) and when I turned the radiator around so that the tubing came from the left the tubing was too long and fouled the rear exhaust fan :(
Other than that it does a very good job on the temps :)
so would you recommend the 420 if your 360 is anything to go by
If the tubing is ok for your build then yes I would, I was going to buy the 420 myself but I decided to go full water cooled instead, but I do believe that the Eisbaer is definitely the best AIO available, it costs more but it's better than all the other AIOs I've seen :)
ok thanks I don't think it'll allow me to place it where I want if the tubes are short
Should state length of tube , also depends on were you out the ports in the rad , if facing the top of the case when mounted at the front or racing the rear when mounted to the top, length is shorter then mounting other way around
