Caporegime
- 8 Jan 2004
- Rutland
Jesus this thread is complete brain rot.
no no no.........grief. The heat isnt the issue, the card isnt the issue. Everything runs fine. I am stating the 5090 runs much hotter than the 4090 yet the temperatures in the software are the same. Therefore i do not believe the temps sensors are telling the truth.
Isn’t this explained by (1) more power = more heat, hence an hotter room, and (2) the 5090 necessarily being more efficient at cooling than the 4090, hence being able to shift heat off the card better?
Yes it is. But not everyone is into facts nowadaysIsn’t this explained by (1) more power = more heat, hence an hotter room, and (2) the 5090 necessarily being more efficient at cooling than the 4090, hence being able to shift heat off the card better?
Hammering the point home isn't possible when the lights are on but there is nobody home. OP cannot understand how his room heats up more with 5090 than a 4090 as in 600W of heat rather than 450W going into the room. He has then concluded that because the 5090 is generating more heat by virtue of the fact it consumes more power and his room heats up more that somehow the temperature sensors are showing incorrect temperatures. It is simply impossible to communicate with the OP that the additional heat in the room is all perfectly normal and to be expected.Just to really hammer the point home:
You could have a card that uses much less power than the 5090, but is far less efficient / poor at cooling.
In which case, the room temperature will certainly be much cooler, but the sensors in the PC might show higher temps than the 5090 despite the lower power use.
Give us a clue I know it's pointless but immortal threads with a million attempts to defeat the OP with logic can be an entertaining read.This thread reminds me of another thread about thermal paste on the cpu forum with legendary status.
I think he means this one... was wondering why it got bumped the other day.....Give us a clue I know it's pointless but immortal threads with a million attempts to defeat the OP with logic can be an entertaining read.
That's not related to your issue.For all the noobs here who rant on how they just now it all...go read. [..snip]
NVIDIA RTX 50 hotspot sensor is still accessible through internal MODS diagnostic tool - VideoCardz.com
NVIDIA removed RTX 50 hotspot readings from standard Windows tools, but the sensor is still active. MODS exposed a 107°C hotspot on an RTX 5070 Ti.videocardz.com
With nvidia 50 series cards nvidia removed access to this, you can't see it with GPU-Z or hwinfo anymore, but like I said, that doesn't mean anything about how hot your card is generally.
Whatever mate your talking ******..read upThat's not related to your issue.
I don't know how nvidia reports the hotspot, but normally they would have several sensors available across the die and the hotspot is the uhh, hottest spot. That's not something you can feel with your hands, or in your room, since it is highly localised.
Some good reasoned argument there, at least argue your point!Whatever mate your talking ******..read up
