i try all u said and still nothing i really think i just broke my motherboard if there's nothing else i can do then its really ****** and thanks for trying to help
Contact Asus.
I will do thanksContact Asus.
Hi,
I was wondering if anyone experience the blackscreen issue where monitor goes black / PC fans still spinning / doesnt respond with power button (hold for 4 seconds) or reset button / so only option left to power off at back of PSU switch or pull out plug.
I had this sometimes when I was testing some overclocking during stress test so can relate this to not enough CPU vcore, however I last experience this during light load (watching youtube) not stressful situation. I have read this could be caused by monitoring tools like hwinfo64 or similar. I did disable the PCH monitoring inside hwinfo64 which warned me when I first open this tool but issue still occurred. At the time I had this tool open all the time because I want to monitor max temps.
I am curious if anyone is using hwinfo64 (or similar) open 24/7 all the time and NOT experience this issue.
For now I have closed hwinfo64 and do not have it open and have not experienced this issue so far, although I did also need to make a small increment to my CPU vcore which came to known during heavy stress test Prime95 custom blend test (using 14GB memory), so Im not sure if this issue occurs because of the monitoring tool or CPU vcore.
I am using the latest Bios 0805.
No, when it crashes it goes to a black screen and PC is still running with all the lights on and everything. Just no screen. It's very random, but apparently some were saying that HWinfo or AI Suite could be causing that somehow. No idea.
It's been pretty stable without crashing too often, so the fan is what gets me the most. I used my setup for a week and had no issues, and then it randomly all started crashing and going to 100% fan speed. Nothing changed that I know of in that time.
I had black screen issues before and it was because the vcore was too low for my overclock. Stressing or not.
A user on OC forum also suggested blackscreen issue while idle can be caused by CPU-Z. Did you have that open?
I am experiencing exactly the same issue, without my monitor programs running. I am running latest bios.
Also read about at least another person with same motherboard having this issue.
Any ideas? Could it be simple incompatibility issues with Windows energy saving controls? Pci, hibernation or similar, wake on lan etc?
Try the chipset drivers from here: http://www.amd.com/en-us/products/chipsets/am4
It installs a customer Ryzen power plan
Thanks, this is better than using the chipset from Asus support download page for the Asus Prime X370-Pro motherboard?
Not sure bro just something to try
AMD chipset drivers and use Ryzen Balanced Power plan, can individually tweak that.
The blackscreen during idle I only experienced 2 times in last 2 weeks (since I got the motherboard).
1st time:
Bios 0805 - I had CPU overclock + RAM tight timings + monitoring tools open
2nd time:
Bios 0807 - I had CPU at stock + RAM tight timings + monitoring tools open
I have not experienced issue so far on Bios 0810 (6 days) - I currently got CPU overclock + RAM tight timings. I use windows high performance power profile.
I did get blackscreens when stress testing CPU overclocking but that made sense as I can relate that to not enough CPU vcore.
Black screen during idle you say eh? I never saw this issue. But last weekend I installed my new 1080 and upgraded to the 0810 bios. also bought a new monitor.
I decided to do some oc'ing on the cpu and during stress test if I left the PC idle for a few mins screen goes black and wouldn't wake up. Also the fanstop light was turn off on the GPU. I was worried it was a dodgy 1080. then I guessed it might of been the monitor. I've turned the power save mode off on this.
Now it sounds like the bios?
Fortunately doesn't happen if I leave things at stock.
I mean idle during light load like browsing websites ... not under cpu heavy load / stress testing. If you get blackscreen during cpu stress test this usually mean not enough cpu vcore from my experience.
