james32 said:Told you all it had bad vcore, research before you buy
overated products.
and no bios update will fix a bad vcore
darkblade said:Lovely photos of a 30" desktop - can't make out the figures though!
What's the FSB topping out at? I've seen people post results on this board using a 6600 running at 3150MHz (525 x 6) using auto voltage, on stock cooler. However, I've also heard that some people need to use a lot more vcore then on p5b and p5w64.
I suppose high temps aren't such an issue for people with decent cooling (water/phase), but there have been a number of posts raised re the voltage droop. What's the max VCore your friend is using and what CPU is he overclocking?
Lustral said:He is using 1.65 V on the Core and has got it to about 3.8-3.9Ghz on the stock cooler.
Lusty
Jay_t said:1.65v on the stock cooler! that thing will be hotter than the sun.
I would have said that 1.50v would be as much as the stock cooler could take. 1.55v for high-end air cooling, 1.60v for water and 1.65v and over for phase change/dry ice. That would be my idea of safe limits.
The Asgard said:I really do think the Striker is overrated and very much over priced. Silly Asus.
Lustral said:Last request from my mate to post this
Happy days
Lusty
benktlottie said:[bottom right hand side of the picture!]
andyr said:Hi Lustral , what ram is your mate using , cheers
SidewinderINC said:hahahaha, i was looking around the picture for something incriminating but i didnt even spot that... well noticed
i did however notice the grinder.
