- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
It's hilarious what a garage will rape you for these days!
I bet they're pulling the old "we only fit parts we supplycause we get a backhanded cut on the mark up on that too" routine...
It's mental when you think for your price you could have serviced it yourself and bought the top mounts/service parts and some decent £1200-1400 coilovers - not that you'd want coilovers on a car like that, but it is still insane that you 'could' pay that disgusting amount they're quoting you for far less quality/amount of parts which are just being chucked on 83k old shocks that WILL still blow/leak/fail soon, then have to take them apart and rebuild them with new shocks again so it passes the next mot/is safe.
I never cease to get a kick out of how much I save whenever I do anything on my cars, even if the job is a pig it's always worth it, personally I like treating myself to new tools with the money I save in labour, and still having extra money left afterwards. Once you have a nice selection of manual and electric/air tools, you can pretty much do anything, then you just need to learn to weld/have a mate who does and you can keep anything forever.
On the contrary, I insisted on OEM parts. It's not "we only fit parts we supply". I thought about going for these coil overs or any other 3rd party. But since I like how the car rides with OEM, I wanted to stick with OEM, not just in spec, but Volvo part.
I know you can work on your own car, but in this case, I would be spending hundreds and hundreds...what tools would I need starting from ZERO to lift the car, take off all the bolts, springs, and put it back together? I need a jack, do springs just go on or would I need to get some compressor thing? Are those like £20?
So I did consider which part I want, I did think about what tools I need and came to the conclusion that the tools that I need would cost more than the labour. That is before tackling the job....never even changed a tyre in my life!
