I am not sure how much of a killing I can get.. I had another look.
Coil Spring - 30683571. Genuine Volvo® Parts & Accessories. Manufacturer Warranty. From the Dealership to your Door.
www.myswedishparts.com
$170 EACH.
Question - what tools do I need to change the springs? Not to coil overs, but to springs.
Name all the tools, including a spanner or ratchet.
So I need a jack...then something to keep the car up?
Toque Wrench to take the bolts on/off the wheels.
Name it all, price it up. Price it up all Volvo parts I need. What is the total of parts + tools cost.
and I will throw in my time for free.
btw, I am not sure why you are going this deep, I started this thread not to complain about the cost, as I stated in the OP I have already committed. I just am curious as to people when the percentage of repair would make them moving it on. The reason I listed the price is to illustrate a percentage £1900 over the value of the car.
Are you buying this direct from Sweden or the states as you keep quoting dollars?
I'd ring Volvo directly and see what they say, you might be surprised, is there not a direct volvo parts website via volvo themselves, like honda-parts.com offers for example?
You would want as I said previously, to do everything the YT video I linked you does, so that video WILL help you. As suspension is suspension, a coilover just adds adjustable dampening/ride height adjustments/better parts, but you get my point right, just like a PSU is a PSU, just modular etc offer more features? - as regardless fitting a shock be it stock/aftermarket/coilover is the same removal/replacement procedure.
Tools wise, I'd say a torque wrench, if you're the UK then use screwfix for a nice selection of brands, IIRC I bought a decent Teng Tools one for around £130 2 years ago that will do pretty hardcore torque ratings, basically anything you'll ever need on the driveway.
A pair of Halfords/Euro Car Parts axel stands, 4 if you fancy doing anything bigger in the future/having it fully level if that helps you.
A basic Halfords toolkit, which as I say is lifetime warranty so ideal, some spring compressors (ebay/amazon etc etc), a basic jack, use Euro Car Parts or Halfords anything from £60-120 will do you, if you wanna make it easier get a low entry bigger jack, and just your basic wheel brace/wheel stud/bolt socket you should have in the boot. A wire brush to clean stuff up, some copper grease for the threads on stuff when you've wire brushed/cleaned stuff for reassembly, nothing major really tools wise. But once you have that selection you can do a surprising amount, more than enough for stuff like this and a service on the driveway.
The basics is, you'd follow said video, for guidance of the removal procedure, but applying it to rebuild/building an existing or new shock assembly. So in your case you'd disassemble your existing shock, and swap the new spring/top mount over. OR do that to a brand new shock (which is what I'd recommend over reusing tired old high mileage stuff, and obviously transfer the old shock dust boot/bump stop) then just refit it the same way they fit the coilover, as i've said above a shock is a shock, so the process of removal/refit is the same, you just have the added step of undoing the top mount whilst you have the old spring compressed with the spring compressor, and then compressing a new spring before fitting the new top mount and it's bolt(s) to it, making sure it's all torqued to spec from the manual, and then undoing the spring compressors, then fitting them back on the car like in the video, you can as they show you use a jack to support the hub when refitting it to save having 2 people there or standing on it and faffing about.
The video applies to your model amongst others including fords
It is worth watching just to show you the disassembly/reassembly regardless of OEM shocks/coilovers, removing/fitting shocks/coilies is the same, as I said above only diffference is you're removing an old spring under compression tool and doing the same to fit a new one then adding the new top mount.
