Oh.Think you'll find it's yes but no.
And if you don't, I will fight you.
Semi-Argumentative.Is this the thread for manual or automatic arguing?
Well, It's one pound for a five minute argument, but only eight pounds for a course of ten.
Not quite the point we were making. There have been people in the thread criticising autos for being dull and choosing completely the wrong gear at the wrong times. But any modern auto will usually have a manual mode to overcome this. It being sloppy or disconnected in your Skoda is neither here nor there...it still allows you as much "control" as a manual, and even though you may have to anticipate the time it takes to change due to an inherent lag, this is really no different to how you have to anticipate the physical time to shift gears in a manual - if you anticipate that the manual override in your automatic is a bit slow and sloppy, and use it with that in mind, you still have as much control over the selected gear, even if you don't feel it actually improves the speed of shifting.
It doesn't allow the same control, and the Skoda not having Paddles is pretty relevant as neither will the Mondeo being discussed (or at least was being discussed), it'll be a Ford Powershift box which also suffers from the same issues.
If i'm in 5th and tell it to shift down 3 gears I don't want a 0.7 second delay followed by 4th gear and then another 1.5 seconds at which point it then changes to 2nd, by this time it's ****** me off and i'm half way into having another go at the stick, I want second and I want it when I move the shifter not a few seconds later. And that's the other issue, if I stick a manual in 2nd, I know it's in 2nd, I don't have to start looking at the display to see if it's complied with my request. I want to enjoy driving and sloppy inputs don't work for me, whether that be the brakes, steering or gearbox.
If my PC had as much input lag as that DSG box in the Skoda i'd bin it. You know when you boot up a really old PC and you start typing an e-mail and the text on the screen is several seconds behind what you are typing? That's how the Skoda DSG feels to me.
Don't get me wrong, it's great in town, not having to use a clutch. But I rarely drive in towns, and the input lag & dithering about really does my box in. If the input lag was eliminated & the shift was near instant then it might be a different story.
Dont confuse DSG with M-DCTSo in summary then, torque converter automatics are better than dimwitted dual clutch automated manual boxes
What if you have a manual with an overdrive? Two extra gears at the flick of a switch!
Hmm, what cars had this as an option apart from the Mark 2 Jag and some old pre 60's American stuff?
Probably other old Jags I guess.
I'm not as stupid as a manual with an overdrive.Stop editing your posts to look less stupid
My 1980 MGB has one.
Albert Dick, vice president of car powertrain technology at ZF, says the 8HP’s deeply satisfying shifts are rooted in factors ranging from the quality of the solenoids to the manufacturing methods to the control software. They’re also a product of a fundamental design that determines how the four planetary gearsets, three clutches, and two brakes in every 8HP gearbox are parsed into eight forward ratios. All one-gear and two-gear shifts use just two shifting elements: one opens, another closes. The 8HP also executes certain multigear shifts in this manner; witness the leaps from sixth gear to third and even eighth to second.
