https://en.m.wikipedia.org/wiki/Shift_time
There's a list of official shift times of various automatic transmissions there. The slowest is 290ms. Even if those times are optimistic, I can't see a human driver ever coming close to that (without a sequential box).
I'm absolutely in the automatic transmission camp, but you can rival a DCT in shift time even with a H-Pattern
That's a 217ms shift on my old MX5, the trailing and leading edges of the ignition timing are the flat shift spark retard being applied and taken back out which is done off the clutch switch. The margin of error is huge though, 25% of the time I'd completely miss the gate and end up somewhere in no mans land between 3rd and 5th. A DCT isn't going to make that mistake
A manual will change as fast as you can change it. Being consistent is the hard bit. 290ms isnt all that quick.
Also what seems to be missed by those who have never driven on, you can drive 100% manual, the gearbox will only do what you ask it to. There is no guessing going on, nor any need to block change anyway. Why go from 6th to 3rd when you can properly go through the gears by counting paddles pressed
I am not quite sure why anyone is still trying to make objective arguments for manuals being quicker.
I think it's likely to be a mix of "never actually driven a good semi/DCT/auto" and some arcane, archaic belief that manual transmissions are for driving gods only, automatics are for the weak!
If all you've driven is an old 4 or 5 speed torque converter, then you don't really have any insight to add for the automatic side of the argument.
Shame he only has a 20hz logger, but it seems the track mode on mclaren has some sort of engineered in ‘kick’ too which slows the change but feels better. Slower change doesn’t necessarily mean slower car either.
That link I shared they were using 300hz
here’s an old vid of my old s2000 at donington in 2012. That thing could hammer thru the gears. 12:45 you might see a car you recognise (NigeP’s golf)https://m.youtube.com/watch?v=N1uiifYqDOI
Also I have this one of a M3 DCT on the N ring at a BMW event I did in 2012. Listen how quick that changes, blew me away back then and finally got my own 5yrs later. https://youtu.be/OyGQPaz-Q0M
Just read the rest of the thread and I must say ericmcn's nonsense postings are quite amusing... And he's still sharing that clip of him driving like a knob, cutting up a mondeo, changing gear poorly, as if there is something to be proud of in there...![]()
The Mondeo in no mans land about to be driven over by a truck?? Unlike said Ford I can make some progress from a slip road, even with **** gear changes to the motorway itself - in that case lane 3, in a few seconds apparently.
Exactly. All this stuff about "automatics are unpredictable / not always in the right gear" is completely moot on any auto which can be controlled in a manual mode. I am not quite sure why anyone is still trying to make objective arguments for manuals being quicker.
I really fail to see what that has got to do with anything... An auto could have achieved exactly the same daft manoeuvre in the same or less time.![]()
Like the MX5, the S2000 box is amazing for changing fast, even on track. But a M-DCT will do a change in 80ms, every time. Especially if you chose the right setting rather than going for the 'feel good settings' that give a bigger thump but slightly slow.
A DCT is effectively two manual gearboxes in one housing controlled by a computer. Until a manual driver has two clutch pedals they will never match a DCT and its ability to blend the clutches.
Not really, maybe this has improved on more recent or expensive DCT boxes but in the wifes Skoda there can be a noticeable delay between requesting a shift & it actually carrying it out, not always mind you.
I've been out in the car to do a bit of shopping this evening so I thought i'd let my phone record wide angle so you can see the rev counter & shift lever, the lag sometimes is massive, enough time to have my hands both back on the wheel before the shift commences. There is also a pretty good clip of me trying to go from 5th to 2nd with 3 quick shifts which results in the car going to 4th and then a big enough delay for me to think it's missed my instruction entirely after me putting my hand back on the wheel so i have another go for 3rd at least at which point it decides to comply & change to second just as I grab the shifter.
It feels so sloppy & disconnected.
ok....
Yes but they are boring, some people actually like the analogue feedback a manual transmission provides.
I see no one answered my last question about the most expensive cars sold and what they had in common -- for sure it was not an automatic transmission, yes? That should be telling itself
