Random thought on the colour part of the equation - if you got an appropriate design of speaker, would it be feasible to get some white gloss vinyl and wrap the speakers?
Something like the 9.1s, whilst you might want to avoid the front faces, may be reasonably achievable to wrap the rest of the outer case in white?
www.youplala.net
Might be worth thinking about, if it opens up options for you
Turning Wharfedale Diamond 9.1 speakers white - Youplala Dot Net
Bought a while ago, very cheap, from eBay, at £30. They need to be gloss white to blend with the bedroom's furniture. Slight repairs needed in a couple of corners. Contents Day 1 - Repairing the corners Dismantle the drivers and connectors. Cut the crushed material clean with a knife. Apply wood...
