OcUK Staff
If you bin by Imc and core it's possible to find 4200+ Imc and high core..but premium will be high.... Simple as.
If we are talking about £1600-1650 which can overclock the cores nicely too that's fine (the extra speed in quad channel is worth it for my workload). Have a DDM-X on preorder with OcUK so not fussed if it includes a delid or not (am delidding and helping others) but feel free to add another £50 if includes a conductonaut (and depending on the die size additional Minus pad) delid/relid. If we are talking higher then forgetaboutit. Can bring the order for the CPU forward to the end of September (30th) if required for the CPU (appreciate delivery will be later after binning) to show no time wasting.If you bin by Imc and core it's possible to find 4200+ Imc and high core..but premium will be high.... Simple as.
4000c17 is am sure is easy with good B die. I just did 18-18-18 because I was showing CPU stuff. I mean 12-11-11- is easy at 4K too with volts.
Even my 3200mhz C!4 entry kit can do C18 no problem on Intel at 4133mhz. I did not try tuning anything so far with testing because I am so busy qualifying on many boards and really don't have time to tune a kit properly takes one week for sure if setting RTLs etc etc....
I'm able to run 4200MHz on my F4-4200C19Q2-64GTZSW on ROG RAMPAGE VI EXTREME. What should I use to test to call it stable? I don't really want to run things for hours though.Almost all CPU cant do 4200 QVL or not. I mean you need to test many CPUs to get 4200 working stable.
Thanks, looks like 4200 is not stable after all, do you guys run one instance per core usually on hci mem test?Hci mem test.
No enough instances to cover all the memory your using.Thanks, looks like 4200 is not stable after all, do you guys run one instance per core usually on hci mem test?
Yeah 1.5v 24-7 is fine.
The 8Pack stuff has higher bin than Tridents slightly and slightly better PCB.
8 pack? Gibbo? Would really like to know. About to buy but want only the best (but quitest - no extra heat by boosting vccin, memory voltage etc. if i can avoid it). Cost isnt no.1 concern for me.
https://www.overclockers.co.uk/g.sk...channel-kit-f4-4266c19d-16gtzr-my-10s-gs.html
these ones are what im using, can only manage 4ghz @ CL17, but works fine at that!
i assume this is the non rgb version:
https://www.overclockers.co.uk/g.sk...hannel-kit-f4-4266c19d-16gtzkw-my-10b-gs.html
listed as a quad but it clearly isnt.
I actually purchased the non-rgb version and I'm running at 4000MHz but at 19-19-19-39. I can't even boot at X.M.P regardless of what I do, VCCSA, VCCIO, dram volts etc
Anyway what timings have you managed to run at is it just 17-19-19-39 or have you tweaked it more?
Off-topic slightly but for gaming what has a bigger impact, frequency or timings? I appreciate any differences are going to be miniscule but some of us get to a point where we want to squeeze every last drop of performance even if it's 2fps (that we ironically won't see on a 60hz monitor lol)
