LG1730P
Apologies for quality of pics btw, im not a natural photographer.
Shows the finish of the monitor off well
For a better view of the image
(although makes it seem blurred, which is isnt)
I must say i love this monitor. The looks are a bit plain for some but are spot on for me, the plastics are of good quality and feel like they should be around for some time. The base is very heavy and keeps the monitor perfectly steady, which is always nice.
Badass has of course given you all the specs and the beginning so ill merely tell you my impressions.
When i started the monitor up i noticed everything was super bright and looking washed out, despite my fiddling with the contrast and brightness i couldnt get the colours to look deep at all, i was not impressed. Then with a few presses of the f'engine button the monitor did the job itself. Making everything look superb. (i have since found the colour menu, and my face was very red
Then browsing windows and the internet everything looked spot on, no ghosting when scrolling up and down web pages, but with a 12ms panel i never really expected anything.
I have also played a few FPS games on it and i must say i have not seen one hint of ghosting. (and to my surprise the 9800 handles 1280x1024 rather well, HL2 at max detail 4AA, 8AF got 30fps, and with some reduction 60-80fps were achieved
After my hunt for ghosting was over i decided to follow up the criticisms of some reviews (namely about colour and image quality), having thought they seemed spot on when the TFT was in isolation i got my old 17" CRT (admittedly quite cheap) and put them side by side, WOW! the TFT blitzed the CRT, making the CRT look very "green", no complaints here about image quality. But then i havent tried any other of the leading TFT's to make a very accurate comparison.
My only criticisms of this TFT so far must be the viewing angles and the blacker than black-black it produces in some sections of games (notably HL2 on water hazard, one of the warehouses was overly dark). The angles seem a bit narrow, slouching in my chair causes the monitor to appear very dark and the opposite is true when only slightly off centre. But its a good excuse for my to sit up all the time. And the blackness can be easily overcome by turning gamma up a bit.
*I believe the only difference between this and the B model is the introduction of a USB hub, which is tucked neatly behind the column.*
Conclusion:
Pros:
Complete lack of ghosting
Vastly superior image quality compared to a CRT
Excellent quality of construction
Cheap for inclusion of DVI and USB (i got it for around £240)
Cons:
Maybe not as good an image as other leading TFT's
Viewing angles a bit small.
Score: 9/10
