Originally posted by Otacon
Just out of interest - what monitor is(are) that(they) ?
They're Samsung 172X's
Originally posted by Mr Woo
Does anyone know if there are any 17" monitors taht don't use "dithering"? This seems one reason to get a 19" as it seems some of those do display true 16.7mill colours....
Originally posted by Baddass
not that im aware of, they all use TN film panels, whereas some of the larger ones use VA and IPS panels for instance
Originally posted by greengiant
so TFT is bad choice for photo editing etc as they don't display true 24bit colour?!?
Brian
well no not really. nowadays colour reproduction can be very good on the more recent TN panels. However, if you're a SERIOUS photo editor, then i would say get a larger model with an IPS or VA panel, or just stick with a CRT. At the end of the day, the colour on TN panels is still very good, just depends on how fussy you are about it all
thread here
if it were me, id prob get a slitghly more expensive one, perhaps a Hyundai L70S
Originally posted by Tob3z
Baddass, what do you think I should get.
2 TFT's, 1 TFT, or CRT?
Its realy hard when your new at this. I will be gaming and photoshop so people keep saying a CRT. Are TFTs going to be catching up with a CRT anytime soon?
If it were my money spending on a TFT now, i would go:
17 inch (my preferred size really at the mo) - (in no particular order really) Samsung 172X, LG1720B, Hyundai Q17+
19inch and bigger (if i were stretching to a larger screen) - Viewsonic VX912......possibly some of the others, but prob not if i was a serious gamer....for gaming, i would personalyl stick with a 17inch model,
hth a bit! [/B]
the L70S is brilliant, and has a very good quality VGA connection to make up for lack of DVI. the only other deciding factor might be the look of the TFT's imo
