Chris Beard said:Run 1:1 then slacken the timings if neccessary.
netby said:I mate
Ballistix PC2 5300 at 2.2Vdimm (default)
could be stable (Orthos blend test- 12h)
at 12-3-3-3 at 400mhz maximum
at 12-4-4-4 between 450 mhz / 500mhz maximum
at 15-5-5-5 between 500 maybe 550 mhz maximum
i do not believe it will be stable at 530mhz at 12-4-4-4 timmings with stock 2.2volts![]()
mine does boot in windows at 600mhz ( effective 1200mhz) at 18-5-5-5 at 2.25Vdimm, and I can do SP 1M, but in less one min. Orthos blend frezze![]()
I say that based in lots of testing of my 2GB kit![]()
humax said:Hi. what does it mean when you run at 1:1
