Like I said, I don't care and I will take your lack of an answer as agreeance![]()
You asked me to agree on something that i was not disputing.
For whatever reason you changed your argument, you quoted me making that statement about WoW with a slide from Skyrim.
WoW has a 2 FPS fluctuation on the 7970 (at best) this is probably because the 7970 is just that little bit less performance than the GTX 680 and there in just drops slightly away from the 60 FPS frame rate limiter every now and then, where as the GTX 680 is able to maintain 60 or more FPS so it does not go under the limiter.
the 7970 dropping to 59 or 58 every now and then does not make it any less smooth than the GTX 680, its nothing to do with frame latency, its to do with GPU grunt in that particular game.
The very same thing may well happen with the GTX 670, given that its got less GPU grunt it may also drop just a little below 60 FPS and it will also make no difference what so ever.
I play games at settings that have my GPU droping off the frame rate limiter by just a few FPS, the only reason, (really the only reason) i know its happening is because i can see it on MSI AB's OSD.
@ Rusty, it was only a matter of time before you came running to fight his corner.
