No, as above they are the same model. The last two digits (77/88) refer to the colour, which is the only difference.
43XD8088
Red = size
Yellow = model
Green = colour
So would you think this years model is worth the extra £350 ?
43XD8088
Red = size
Yellow = model
Green = colour
very subjective point.
like i said it depends how long your planning to keep the tv for and how much value you associate to £350.
me personally, I would say no. It's 50% more for less than even 20% improvement. However if your the type of person that buys a tv once every 10+ years. Then it's probably worth going for the newer set as you should get the best you can afford in that sort of situation. if you upgrade regularly then get the best bang for buck.
Those Sony sets can be had for 599 now at Very.
Is that a decent price for what you get?
I take it paying similar for say a 49" would get me a worse TV?
The models i listed ? Showing as £649 still for me ? Got another link?
what do you have now ? since have not seen any ~40" 4k's I would switch too, so will probably run it into the ground.
with size limitation I am not convinced you will improve much on your existing one - technology improvements being directed to bigger setsAtm i have a Samsung ue40ju6550u 4k tv which ive had coming up about 2 years now. I only pais £408 new at the time. But im hoping picture quality would have got better since. Only real issue i have with current tv is motion blur
missed that
- ironically ju7100 from same year as yours seems maybe last 120hz ~40" panels and might have improved motion issue ... change your room layout to accomodate a bigger set.
