Best 7950?
Yeah it seems the 7950 Vapor-X is voltage locked - at least the one I have is.
So anyone who buys one should be wary of this.
I asked Sapphire about it and got this as a reply:
"Dear Sir:
We recommend you use CCC of power control function."
:rolleyes:
"Dear Sir:
:rolleyes:
Are you going to RMA/DSR it like the last one then?
I'm going to be getting one of these in the next few weeks, probably the HIS. Anybody got any idea how much a Phenom II 965 will bottleneck it?
How is it far better if it is voltage locked because your max oc is limited now, or do you mean it is quieter?
It's silent even at 1115Mhz :)
Well, of course it isn't silent :P But I can't hear it over my case fans.
Lol I like quiet too.
Slight disappointment for me as I noticed last night that Afterburner max core setting is 1100 with my TF3.
Real shame because I think it would hit 1200 with a touch more voltage (although I suppose I don't really need that).
http://forums.overclockers.co.uk/showthread.php?t=18431335
Try this - it lets me go to 1200 :)
I got it wrong, it actually increases my max clock to 1710 :P
Good Grief.... Don't run clocks that high.
Unlocking xtreme volts / clocks in MSI Afterburner is for those who bench on liquid nitrogen
For every day use keep the extreme volts / clocks locked and use the standard overclocking. using extreme will fry your card in weeks or days.
1200Mhz is about the most you should run for every day use, if you can't get that on the voltage adjustments you have without unlocking xtreme then your not going to have 1200Mhz. :)
