Best bang for buck CPU - i7 4790k upgrade
Caporegime
21 Jan 2010
Hi folks,
It has been a while since I upgraded, and it was a pretty simple task from what I remember (went from an i7 920 D0 Stepping to an i7 4790k). Both were "top end" CPUs easily identified and paired to a Mobo, RAM. Maybe I am just getting older, thicker, or the brand naming schemes have indeed got way more complicated to follow but I am feeling a bit lost :D.
I think I am looking for an inexpensive mobo, RAM, CPU jobbie that is at least comparable for single core performance but offers something in higher productivity loads (usual home worker stuff - PPT, XLS, streams etc). I love CS:GO which is pretty low end but I may get into something higher end as my kid grows up and I get some time back.
I was tempted by the 5600X but I can see it is slightly worse for single thread performance. I then looked at the Ryzen 7700 but it is quite spenny. I have then looked at the 7600 which seems to be a significant jump over my i7 but once I add mobo, RAM, etc. I am into £500 territory.
Ideally I'd like to stay at £350 total. Is there a workhorse CPU I should be looking out for? Intel or AMD to be fair; although I hear horror stories about BSOD on the newer Intel stuff.
You can get a 14400F for around £150, which performs similar to the 12600K and then pair with a cheap B760 board and 32GB of DDR4:
My basket at OcUK:
Total: £176.98 (includes delivery: £3.99)​
About £20-£30 over budget and there's a cooler in the CPU box.
It shouldn't be, the single thread performance of a 5600X is way higher than a stock 4790K.
Wowza - that 12700K does seem like great value. Is there any benefit to go sans graphics (I assume that is what the KF means?).
My basket at OcUK:
I will check that out - is £50 "top-up" worth it for the 12700k that Glanza suggested?
And you're right RE: 5600X, I misread the graph!
Thanks both. Helped me immensely :)
I'd say so, IGP and 2 P-Cores isn't a bad deal for £50.
12700K has 8 P-Cores and 4 E-Cores.
14400F has 6 P-Cores and 4 E-Cores.
They're likely to have the same die, despite the name.
Sorry to bother you again - I think I am going to pull the plug on this except with this RAM:
Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey (SKU: MY-0AJ-TG)
And the board you have listed is now out of stock. I assume this is the direct replacement? I can't see any discernible differences.
Not looking to creep here but presume there is nothing exponentially better RAM/Mobo wise for a little more cost? I won't be upgrading or overclocking.
A 5800X, A520/B550 plus 32gb of 3600mhz memory can be done for £250 which sips power, offers a silly amount of performance for the money and doesn’t require much in way of cooling.
Is that second hand?
I think the 12700 is tempting because it seems extremely cheap (£200) but the power consumption did put me off placing an order yesterday hastily.
5700X3D - £175 or cheaper if you order from China
ASUS TUF Gaming B550-PLUS (WI-FI II) - £90
32GB DDR - £50
Cooler of your choice.
That'd be my play. You lose some MT performance but the gaming performance and efficiency is excellent.
32GB DDR - £50
Great minds and all that -- just assembled:
Corsair Vengeance LPX DDR4 32GB - £60
Asus TUF Gaming B550 Plus - £106
AMD Ryzen 5800X - £150
I am very suss about the 5800X at that price; but it seems the going rate for "new" second hand ones.
Edit: 5800X is too suss at £150 so back to drawing board :D
Edit: Locked in 5800X at £168 - so £333.95 total.
Do I need to buy a cooler separately? :cry:
Yes I think you need a cooler. Thermalright Assassin Spirit 120 is a bargain.
I wouldn't personally take the 5800X over the 5700X3D if you're into gaming.
Yes I think so.
How come? Cost saving or is there something significant I am missing?
Edit: its £20 more for the 5700X3D. I can see gaming performance is better on the 5700X3D vs. 5800X.
Worth it for 20?
If you are spending £300 you might as well get am5 if using imports for the cpu.
Ram £90
650 Mobo is £110ish
7500f <£100 of 7700 ~£120
Cooler £15 (postage!)
Edit: beaten by the cat!
This is stressful, lol.
I can do an AM5 build for £45 more than the AM4 build. Is this really "better"? I can see power is much better and therefore heat may be easier to manage...
Corsair 32GB 6000mHZ - 88
Asrock B650M - 111
7600 Ryzen - 180
+cooler
I plan to use my 5700XT as well; I presume that isn't an issue with any of my ideas so far.
