Just google - HWinfo.OK could be SpeedFan issues - is there a better CPU temp app?
install it hen when you open it you get a small box asking with info you want tick sensors only
i had a 7600x overclocked with a peerless assassin 120, your CPU as more cores but there is no way it idels at 60, they do tends to be warm at high 30's but under load the most i would see is mid to high 80's and i was pushing the CPU for all it had
