I spent 2 hours in richer sounds listening to 3050s and bronze 6s ended up keeping the 2020is as I prefer the sound, will be going back to listen to kef q550s and fyne 302s
Pound for Pound, second-hand is always going to be better value than new. Speaker designs evolve gradually. That is to say, what was a very good speaker in the past is still likely to be a very good speaker in today's market too.
The great thing about used is that any issues with the design or reliability will have come to the surface and be well documented. In some ways that provides more reassurance than buying new. For example, a classic entry-level speaker back in the 80s was the Heybrook HB1. In '83 they were around £150. In today's money, with the effects of inflation, that's roughly equivalent to spending £480, so hardly entry-level money today. Over the same period the cost of manufacturing has fallen, so in real terms the Heybrooks would be pitching against the likes of the Dali Zensor 3 at the £300-£350 mark. As good as they still are, old HB1s had a problem with the foam surround on the bass cone. Over time it went brittle. It can be replaced as a DIY project, so it's not a deal breaker, but you'd want to factor that sort of thing in with any potential purchase. So it is with other used speakers. Any major problems will have come to light generally.
Where things start to get a bit messier is with opinions on sound.
We all have an idea in our mind of what "good sound" is, but each of us has a unique version of that, and so any subjective reviews from owners might need to be taken with a pinch of salt. Much depends not only on the speakers but also the room and the partnering equipment.
With that in mind, one thing I'd be careful of is partnering the Ceol with speakers that are going to expose its limitations; the equivalent of a sonic magnifying glass, if you like. Proper journalist reviews will help you pick your way through the older speaker models to avoid this issue.
I can definitely see your reasoning for going second hand. You have to really know your speakers to pick up a proper bargain though I suspect. Probably a lot of overpriced junk out there too. Especially on eBay.
Those look very nice Indeed. Although refurbished unfortunately.
Not sure my Denon N9 would do them justice though![]()
so what if they are refurbished? they come with a 12 month warranty.
if you aren't happy send them back within 12 months.
you are getting £2200 speakers for £450. obviously there is going to be a compromise somewhere.
I have Monitor Audio BR5’s and they are really good for the money, pack plenty of punch and are not too big or imposing.
Well just for reference I picked mine up for £170 in very good condition. The only downside is I may need to upgrade my centre speaker to match.
You may be confusing the newer Bronze 5’s for the older BR 5’s?You got a fantastic deal there then, these are £549 pretty much everywhere brand new.
https://www.whathifi.com/monitor-audio/bronze-br5/review
Yep it’s quite a minefield. To be honest I doubt I’d have the ability to be able tell them all apart by listening so I just went for something at a reasonable price from a reputable brand. Would love to be able to spend big bucks but it would probably be lost on me.
I do worry about this too
Maybe another set of 2020i's would be fine.
at your price point you should really be looking at second hand and on avforums classifieds.
obviously you are then limited by what's available at the time on there and is local enough to collect.
i picked up all of my equipment from there. including a brand new BK subwoofer someone had bought then never used. he provided the receipt for proof it was a month old and came in original packaging sealed.
£400 new won't get you a lot.
Something you might have possibly overlooked here. wouldn't it be prudent to upgrade your amp and move that one to your pc ?
