- 30 Jun 2006
- Cardiff
IvanDobskey>How did you get on with the 3050? They have the new 3050i model out but haven't listened to it yet. I loved the 3050 when I had it.
Only decent speakers I have had up until now are the 2020i's, which are fantastic for the money.
I did consider the 3050, but they are just too big for my living room really. I went for the Monitor Audio Bronze 5's in the end at £475.
Hopefully will get them on Wednesday.
As much as I like MA Bronze/BR/BX 5s, I'd be surprised if you found them much of an upgrade from the Aegis Evo 3. This is especially the case if the room is small.This thread has made me look at upgrading my speakers (~15 year old Acoustic Energy Aegis Evo 3 floorstanders). Let us know how you get on with the Bronze 5's.
Damnit, I can feel my wallet twitching (in a good way).![]()
@ivan nice looking setup
Looking good glad your happy with them.
Have you mass loaded them?
Despite being 15 years old, I think those are pretty good speakers
Speaker tech hasn't really changed much over that time period, so I'd say you'd have to spend a bit more to get something significantly better. Maybe the silver 6's. I noticed there's a refurbished set on richer sounds for £449.
Hoping to get my bronze 5's delivered tomorrow, so will report back. Just hoping my Denon N9 is up to the job.
The new speakers look great in situ. Very nice!
Thanks for the advice, maybe I'll keep the AEs for bit longer and improve my CDP instead (I've been looking at mods such as replacing the clock).
Cheers
I have always skimped on the audio side of things in the past, both for my pc and AV setups.
Bought some really nice headphones couple of months ago and realized what I was missing.
audio is just as important as the screen if not more important IMO. as in the music, etc can really set the scene. there is a reason why IMAX cinemas have a ridiculous number of speakers and sound fantastic.
Definitely true
Happy to stick with decent stereo for the time being though. Quality surround sound could get expensive real fast and I do use my setup for playing music a lot. Plus there's the room size issue and running cables....
I think the bare minimum usually for home cinema is 3.0 or 3.1.
Essentially the centre speaker is the most important. It's the one the majority of spoken voice comes out of. So you may find it sometimes you can barely hear people speak as it's not mixing well to 2.0.
I would definitely get a centre and sub. Those 2 add so much. The rear speakers add little compared to those 2.
Would need a new amp first unfortunately, mine is stereo only![]()
maybe food for thought for the future.
i originally had 3.0. then went 3.1 then went 5.1.
i felt the biggest difference was going 3.0 to 3.1 and 5.1 only really comes to life with decent movies. for the majority of viewing tv shows it's pointless.
