Best house alarm system?
I should point out that nearly all alarm systems can send you an SMS to your mobile regarding recent events (intrusion, fire, tamper etc).
Either as part of their range or a bit of add-on kit.
This kit starts at around £70
All a monitoring system does is send the same message via SMS or dialup/IP/3G or Redcare$$$ to a flunky who will check the system and decide to ring the Police or not.
Essentially you are paying extra to give the police a tipoff, when really insurance covers everything anyway.
Good luck keeping tabs on the SMS centres when they change their numbers. Be better off giving the money to your neighbour. If you go that way just buy a bloomin speech dialler and be done with it.
Attention all dog owners, I'm sorry to tell you but your house smells of dog. You either have polite friends or no friends at all (which is probably why you own a dog) to tell you this.
skip image
On top of the dog. License is easy to get.
Not on topic.
And:
You may post images providing they are hosted by a well known image hosting website, such as imageshack, photobucket etc.. Directly linking to images on other sites that are not expressly for that purpose (known as Hotlinking) is not permitted. Hotlinked images will be removed with an infraction notice issued. Repeat offenders will be suspended. The sharing of images from your own personal web-space is acceptable providing you are the owner and give permission to do so. However, the OCUK moderation team reserve the right to replace or remove any image that is suspicious of being hotlinked or unknowingly hosted by a members personal web-space, as it is not possible to identify those where permission has been granted or otherwise. Such decisions will not be overturned. To avoid complication, we strongly advise that all images are hosted by a image host as mentioned above, which can be easily identified as so. Images containing nudity, adult or offensive material, including swearing is prohibited. Please check your images before posting. No watermarks or URLs for sites containing content that wouldn't normally be allowed such as competitors, adult sites etc. Any images of such nature will be removed and your account immediately suspended or banned. Unless otherwise agreed by the moderation team, images must no wider than 1024 pixels wide.
Yep, I think I would go with a GSM signaller, just add a sim card.
I think a lot of this depends on if the police can get to the house in time or not, I'm thinking if an alarm is going off the chavs are not going to hang around, so all a monitoring or GSM comm is going to tell him is to get back home because his front door is open.
I haven't read any of the thread but I bet some say 'a dog'.
I worked in a Juvenile Prison and not one inmate was EVER put off by a dog in the house.
Well obviously, hence why they are in prison. That would be like asking some people in a swimming pool if they are put off by the water.
They went through a lot of dog alarms before finally being caught but mostly for drugs.
Any adult burglar will also have a massive success rate with dogs in the house.
Dogs are quite useless at being an alarm.
At the very least OP put some dummy boxes & cameras up.
Depends,
Many boxes now have a knightrider led that requires power, a dummy probably won't.
Also a lot of dummies are put up in an obvious 'no way would an installer site it here' position.
Most CCTV has IR leds, at night these show up on a mobile phone camera as a point of light, dummy cameras don't have this.
Also every dummy CCTV I've seen does not have an IP68 box to put the cables into, or has amazingly tucked them into a 5mm hole somewhere.
You can fake some stuff, but any chav with a braincell will see through most of them.
I probably shouldn't mention how easy alarms are to disable :o
Not disputing the unreliability of dos in general but why do people who recommend dogs always recommend big dogs? My family have kept Lhasa Apsos for years and they don't tolerate strangers at all, if the object is to have a living alarm then a big dog doesn't gain you anything imo.
I'd like to know this too, as the response times on panel zones are very quick if you are to tamper with cables, What with DT's having anti-mask features etc, do share your knowledge :o
Edit: I think someone has been watching too much Beverly Hills Cop
Depends,
It was just a statement basically saying "Just put a deterrent on the outside of the house" which will deter a % from even coming up the drive.
A dog will also be a deterrent for a % but your property could be damaged before your living deterrent kicks in.
So absolute basics would be dummy deterrents then a barking dog but this wouldn't deter a professional or drugged up burglar.
Of course stick proper alarms up with proper LEDs and a pro should spot the real thing and will make a decision on how much time he might have before neighbours get involved.
I would also like to see you disable my outside alarm.
Tamper with my internal box and my two alarm boxes have their own batteries.
Tamper with the alarm box and it goes off.
Yep, really a blue box in the right position powered from a 12v brick is going to look legit.
I'd imagine that a dog, big, yappy or otherwise would not attact any more attention from neighbours than being the usual irritating dog that you'd just wish would shut up.
The time to remove the screws from the alarm box is roughly how long the bell would remain active, it will still go off for those 30 seconds minus entry delay.
Alternativly bell boxes don't always have the rear tamper installed as it's just another callout failure, you then have access to the 6 core, same process.
I could time it I guess, I've got a veritas panel on my bench now.
shoddy installation of ungraded kit... I just hope you aren't an installer. Rear tamper is necessary and if do e right first time there are no callouses. I maybe had one hen the ridiculous winds were about, that was it. But even then you would have to get to the bell box, disconnect it, break in to the house, find the panel, pop the fuse and then disconnect the battery...not really going to happen on a proper install now is it.
Would agree, grade 3 blocks and the protection on DT's make them very good.
The panel is the weak point, specifically the simple level signalling between BB and panel.
Don't worry I'm not an installer but I did work for Scantronics years ago on telemetry. Best designs in the business at the time, best technical managers I've ever met.
You'll know that some installers are cowboys then, so tamper circuits are often 'optimised' as frankly who is going to tamper with stuff on a domestic? Especially a BB.
They are also supposed to be bolted down but many are still fixed with rawlplugs.
Disconnecting a BB (cut wire) will still trigger it (SAB) or popping the fuse and the battery will still trigger I think. Panels with dead batteries will alarm when the power goes off around here, so same thing.
The fact remains, the alarm will only continue to sound until shortly after the front panel is removed, which is why it's important to locate the panel in the most inaccessible site possible. This is the real benefit of ARC monitoring in that somebody has to respond.
Is it really worth the hassle/money to put in house alarms these days?
My experience is once a house alarm goes off no one checks, they go on for hours annoying the neighbours and the box looks naff on the house :P
