CompMan said:I never said 30c full load i am new to overclocking intels
i can use the 4300 without any crashes at 3.2 ghz stock vcore
have done for 3 days without problems i take it it needs to pass orthos and prime to be valid then? ok i learn again apologies for my blooper.
+0.1 ram +0.1 chipset however you are correct it does fail orthos
and prime at stock voltage im currently trying 3ghz on 1.33 volts
and running Prime online thing current temp is 50c after 10 mins running
i will try see what gets me passed on orthos / prime at 3.2 ghz over the next week.I take it ill need +0.2 on the chipset and 0.1 on ram and something around 1.45-1.5 volts on the vcore then?
It will need around 1.5v to be stable in orthos @ 3.2ghz
Idle temps mean nothing its load that matters.
