- 10 Aug 2010
- Somerset
With speakers could I hook them up so anything that went through tv would have sound ( ie the pc, the xbox etc without having to switch wires? ) just trying to work out what I could do
And I'm probably going for a 680 now as opposed to a 7970 as I think they are slightly better ?
This is the most expensive thing I've bought In many years and It will probably be the last "toy" I get for a very long time so I want it to be special and last me a long time
Sorry yeah, so you want to use the speakers with the TV basically? Does your TV have a 3.5mm jack you could plug them into? If so, you could plug them into that. However if you're then just using the PC on a monitor, you'd have to plug them into the PC. Someone else might know a better way if that's what you want to do.
If you're mainly watching stuff on it personally I'd get the Dell - you could also get away with a cheaper GPU if you're not running 120Hz.
