Best Thermal Paste
I recently changed my standard cooler for a Nero S and Arctic cooling MX4 paste and used arcticlean fluid all bought from here
I used the spread method and the results 10c less than OEM at idle and over 10c whilst gaming
Indigo extreme ;)
yeah but can't get it anywhere in uk as it far too expensive plus (rip off) for european delivery charge)
I can see the chart table here: http://indigo-xtreme.com/images/skineelabschart.jpg but I guess MX4 is 2nd best to this Indigo extreme!
Also someone isn't happy with indigo extreme on their H50 from the forum elsewhere read here:
Indigo Xtreme for Intel Core i5/i7 (LGA1156) and the corsair H50
hi troops!!
i fired one of the indigo extreme interfaces on my i7 with the h50 and my temps are not good...im not sure how i can get them better and im not keen on frying the cpu gain to get it to work...anyone else tried it and what results are you getting??
cheers
Gordy!
i squirted a ball of paste in the middle of the cpu. slightly bigger than a pea and let the weight of my cooler spread it around the cpu itself. worked well for me.
Have just used MX4, CPU temps down 3 degree's, core temp range a lot more even, l'm H2o cooled so my GPU will run that bit cooler to. As l cool the CPU first then the GPU, LOL two for the price of one..;)
I used mx3 when I setup my water cooling. Seems to do the trick fine, can't imagine another paste giving noticeable difference really. I prefer to put a dot in the middle then spread evenly with a credit card to ensure its fully covered
