- 13 May 2003
Surely bringing it up to room temperature reduces the delta T from inside to outside so you get a lower temperature gradient and thus more evenly cooked steak?
For the first time ever I've bought a rib eye steak and now I wonder what is the best way to cook it?
That's what you would expect, but check out the serious eats page and their experiments with it, it doesn't make any difference. I've tried both ways and there's really no noticeable benefit from taking it out early. Salting early is a whole different matter, that makes a big difference.Surely bringing it up to room temperature reduces the delta T from inside to outside so you get a lower temperature gradient and thus more evenly cooked steak?
This is generally how I do it. Wants to be a couple of inches thick though.
https://photos.app.goo.gl/o3MDertsyddPexoj8
I've never understood the point of salting a steak early. It just draws out water and it's water that makes the steak so juicy.
As Papalazaru said, the moisture is drawn out, which dissolves the salt and the brine is then absorbed by the meat, seasoning it deeper than just salting the outside alone does.I've only found a difference when I have my fridge on really low and I have the steak stored right above the freezer compartment so the steak is near-frozen.
Interesting idea, never thought of using the chimney starter.
Also, what is this about putting it in an oven?????????????????????????
Saves on charcoal and gets up to speed v fast. Also funnels the heat right up to the steak.
Other bits I tend to do:
Buy decent steak direct from the butcher. I use Eric Tennant in Newmarket
Unpackage steak in fridge onto a plate well beforehand i.e. morning of cooking.
Out of fridge an hour before. For me this does make a difference because I don't want the core to be cold when it goes on the BBQ.
Season well with salt & pepper. Sometimes I use a rub but less than I used to.
When I got a Sous Vide machine I did for a while sous vide my steaks first but I realised when using a serious heat to get a delicious crust, the middle was cooking more than I wanted it to. Room temp onto Chimney Starter is my ideal now I think.
Edit: Properly resting after cooking it is also a key factor.
Sear in pan, then place on a butter wrapper in an oven for however long that steak needs to be done as ordered.Also, what is this about putting it in an oven?????????????????????????
I skimread the SE bit about bringing to room temp and how it doesn't make much difference. In my mind it still helps because you're not taking a cold steak straight into a hot pan. Something like how you let a steak rest maybe, to relax the proteins? I dunno. Happy to be proven wrong but having it at room temp doesn't hurt the process anyway so it's no biggy.
To cook a steak and get that nice outer crust with the milliard reaction, the water first needs to come off. A very wet steak on a hot pan simply cause the water to start to boil and you end up boiling your steak and getting a tough rubbery outer. You want the steak to start searing immediately.
The science is a bit more complicated than that. Read the Serious Eats link I posted above. It does clarify the importance of salting at least for 40mins because in those first 40mins you do see the moisture drawn out. But what happens (in my layman's terms) is that goes back inside the steak and brines it. It also seasons it in a lovely way. Honestly, give it a whirl - you'll never go back. It's night and day.I've never understood the point of salting a steak early. It just draws out water and it's water that makes the steak so juicy.
