Bf6 optimisation questions
Good advice, only thing I'd add is that 250dpi is pretty low, ideally you'd aim for 400 or 800 as minimum (I think for BF6 I'm 800dpi / 12 sens / 98fov @ 2560x1440p) Other windows setting to check is Enhanced Pointer Precision, but IIRC having Raw Mouse Input active in game ignores this setting
I assume my settings might be higher with a 5120x2160 setup, will need to try and see what settings are best
@ 3440x1440
All on the High Pre-set, which for some reason sets to Custom.
Think the Mesh setting is set to Ultra
Capped frame rate @ [165]
Motion blur reduced down to the min
Resolution Scaling [Off]
DLSS [On]
FG [On] (2x)
Runs between 135 - 165, typically the higher end and feels very smooth.
Whats the recommended settings for a 5090 with an 9950x3d using a 5k2k monitor, I was told by a mate to use the txt file to disable certain things via a user.cfg file, To be honest the game runs great apart from my DPI lol
