BitFenix Prodigy Mini-ITX Cube Case
With a new modular PSU... still tight space to work in! lol
Doesn't help that I decided to use my braided cables even though you can't see them once the sides are on the case! ha
I think the next time I'm in the case I'll remove the braided extensions to tidy things up a bit - no need for them in a case with no windows anyway.
F*&k it - gonna sort out the cables some more now!
Has anyone put an LED fan in the front? If so can it be seen through the grills at the front? I was hoping for some super subtle lighting for the grills.
Also going to put a shameless plug for my watercooled build log in here for those that haven't seen it http://forums.overclockers.co.uk/showthread.php?t=18423195 :D
You would be able to see fan lights through the front.
the whit case has a solid front so it wouldn't have the same effect as the black which is a meshed front
lol felt the same but when i open my case i love seeing my cables :) plus i like to show it off to friends and interested family!
Loving these prodigy builds.
Once I'm finished with my main rig I am planning a watercooled prodigy, but the watercooling is all external, it's already in place because I can simply add the cpu/gpu to my current loop. The prodigy build will be this 2700k + hopefully a gtx660 if it fairs well in power/performance, and will be for folding.
The problem I have is how to get the tubing into the case because as far as I can see there's no wc grommets? The best I have come up with is something like mnpctech's '"Steampunk" 240 Radiator & Fan Grill' mounted in the roof and pass the tubing through one end, fan on the other. could get dusty though :/
I'd rather not dremel something into the underside which would seem the logical choice, lol.
24 pin, CPU 8 pin and CPU 4+4 pin are non modular.
Sata cable x 1 connected
Molex cable x 1 connected
PCI cables x 2 connected
I also have a bitfenix molex to 3 fan connectors to run the fans at 7 volts. Off those 3 connectors I have a fan splitter in each so I can run all the fans at 7v (6fans).
Question if i got the bitfenix molex to 3x3 pin would they all run at the 7 volts ? or would they not? because I was going to get one for my case next week when i order my psu.
I'm having a nightmare. my crimpers arrived but where slightly twisted, still useable but annoying, so i'm getting a replacement set.
I think I'm just going to put it together with the corsair modular cables I have for the minute until I get all the wires done.
Just so I can post a pic really, as there aren't any white ones in this thread yet.
I'm also not going to bother with a GFX card for now.
And I'm going to go with a lower powered CPU
I was going to use it as my main rig. But now i'm just gonna keep it for web browsing and media, and keep my other rig for gaming.
I might get one of these too.
